Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Errors installing new modules from NPM registry (using Module Manager)
#1
I have tried to install winax module using System->System Manager->Module Manager app, and I received the following error:
gyp info using node-gyp@12.1.0
gyp info using node@24.3.0 | win32 | x64
gyp ERR! find Python
gyp ERR! find Python Python is not set from command line or npm configuration
gyp ERR! find Python Python is not set from environment variable PYTHON
gyp ERR! find Python checking if the py launcher can be used to find Python 3
gyp ERR! find Python - executable path is ""
gyp ERR! find Python - "" could not be run
gyp ERR! find Python checking if "python3" can be used
gyp ERR! find Python checking if "python" can be used
gyp ERR! find Python checking if Python is C:\Users\WDAGUtilityAccount\AppData\Local\Programs\Python\Python311\python.exe
gyp ERR! find Python - version is ""
gyp ERR! find Python - version is  - should be >=3.6.0
gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED
gyp ERR! find Python **********************************************************
gyp ERR! find Python You need to install the latest version of Python.
gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
gyp ERR! find Python you can try one of the following options:
gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
gyp ERR! find Python (accepted by both node-gyp and npm)
gyp ERR! find Python - Set the environment variable PYTHON
gyp ERR! find Python - Set the npm configuration variable python:
gyp ERR! find Python npm config set python "C:\Path\To\python.exe"
gyp ERR! find Python For more information consult the documentation at:
gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
gyp ERR! configure error
gyp ERR! stack Error: Could not find any Python installation to use
gyp ERR! stack at PythonFinder.fail (C:\Users\WDAGUtilityAccount\Documents\NodeActa-dev\Apps\Modules\npm\node_modules\node-gyp\lib\find-python.js:306:11)
gyp ERR! stack at PythonFinder.findPython (C:\Users\WDAGUtilityAccount\Documents\NodeActa-dev\Apps\Modules\npm\node_modules\node-gyp\lib\find-python.js:164:17)
gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
gyp ERR! stack at async configure (C:\Users\WDAGUtilityAccount\Documents\NodeActa-dev\Apps\Modules\npm\node_modules\node-gyp\lib\configure.js:27:18)
gyp ERR! stack at async run (C:\Users\WDAGUtilityAccount\Documents\NodeActa-dev\Apps\Modules\npm\node_modules\node-gyp\bin\node-gyp.js:81:18)
gyp ERR! System Windows_NT 10.0.22621
gyp ERR! command "C:\\Program Files\\NodeActa\\Client\\node.exe" "C:\\Users\\WDAGUtilityAccount\\Documents\\NodeActa-dev\\Apps\\Modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
gyp ERR! cwd C:\Users\WDAGUT~1\AppData\Local\Temp\packages\winax\node_modules\winax
gyp ERR! node -v v24.3.0
gyp ERR! node-gyp -v v12.1.0
gyp ERR! not ok
Reply
#2
Some NPM modules contain native code, usually c/c++.
Sometimes they have precompiled binaries, but if they don't, or if binaries require a different version of node.js, Module Manager will trigger binaries compilation using node-gyp.
node-gyp requires Python and Microsoft Visual Studio (with Desktop Development with C++).
If you look closely at reported error, you will find the part:
    gyp ERR! find Python Node-gyp should be able to find and use Python. If not...
Solution: Please, go to www.python.org, download and install the latest python version. During installation select "Add python to PATH" option.
You can also find something like this:
    gyp ERR! find VS **************************************************************
    gyp ERR! find VS You need to install the latest version of Visual Studio
    gyp ERR! find VS including the "Desktop development with C++" workload....
Solution: Download and run  Microsoft Visual Studio Build Tools (https://aka.ms/vs/stable/vs_BuildTools.exe) and don't forget to select "Desktop development with C++"  option.
WARNING: You might need to restart NodeActa client or even entire PC after installing Python and MS Build Tools
Reply
Forum Jump:
Users browsing this thread: 4 Guest(s)
